Custom True Dual?...
Is There Anyone Out There With Pics Or Sizing Of Lengths Of Pipe For True Dual Setups For Over The Axel For Custom Build? 3" Would Be Preferred, I Would Like To Put 2 Bullet Mufflers 1 In Each Side W/ An X Pipe. I Like TSP True Duals But I'd Rather Have Them Go All The Way Back Without Cutting So Many Pieces In The Pipe. I've Seen It Done Before, Just Would Like More Info Or If Anyone Took Time To Put Together Like A Cut Sheet..
Thanks, You Help Appreciated.
I don't believe that you will be able to get two 3 inch pipes to go over the axle. 2 1/2 inch pipes are about as large as will fit in the small space. But, I assure you that two 2 1/2 pipes are as large as you will ever need unless you are running something over 500 horses.
Actually, it can and has been done.
