Nick Williams TB question
Old 01-17-2006, 08:18 PM
93LS1RX7's Avatar
Default Nick Williams TB question
Hey guys I am running my LS1 in a RX7 and I need a hair more clearance on the leading edge of the TB.
There looks to be a lot of "meat" to take down but I dont want to get into anything important and screw up my TB.
Anyone have any idea how much I can safely take off the flat top part of the TB and also how much off the top leading edge. ie the top 90degree corner.
I do Not mean the actual opening where the air flows into the motor but rather the top square section that the IAC mounts to.
Thanks
Old 01-17-2006, 08:56 PM
black01_WS6's Avatar
search for nick williams on the site and give him a pm. and he can help you out on that one.
Old 01-18-2006, 08:25 AM
Nick Williams's Avatar
Post a picture of where you need to cut and I will tell you how much room you have to cut. Or you can email it to nickw_61@yahoo.com
Old 01-18-2006, 04:38 PM
93LS1RX7's Avatar
Nick
I have drawn a red area around the portion I need to cut. I would like to get as close to the IAC as possible.
I think my biggest concerns are the top center bolt in the TB and also if there is anything in the area I may get into.
Old 01-18-2006, 04:40 PM
93LS1RX7's Avatar
Just to make 100% clear, the pic was taken from the drivers side of the car
Old 01-19-2006, 08:13 AM
The only thing you may get into is the bolt hole. That won't affect anything but how it looks. You really don't even have use the top bolt if you just wanted to fill it in somehow.
Old 01-19-2006, 08:31 AM
93LS1RX7's Avatar
Ok so I can take it way down?? How close can I get to the IAC motor before I start getting dangerous?
Thanks again for the help Nick
Old 01-19-2006, 09:16 AM
Just pull the stepper motor out and look thru the hole. You will see how far you can go.
Old 01-19-2006, 10:02 AM
93LS1RX7's Avatar
Ok I just wanted to make sure there wasnt anything that I couldnt see up in that area.
Thanks Nick
