qtp cutout wiring help please
For ground I used the black wire on the cig lighter, for power I extended the red wire and connected it to the radio fuse. You can also use the pink wire behind the traction control switch. Make sure you use a "switched" power source, so when the key is off the light on the cutout switch will not draw power - my switch light goes off along with the radio when I open the door.
On my car (no TCS), I found an empty fuse spot in the fuse panel on the drivers side of the dash. It was only on when the ignition was on, so I used it. It was real easy to run the wire up there.
For the groud I just used one of the screws that holds the console down. My switch is in the ash tray.
Originally Posted by 02BEAST
How did you put your wire in the empty fuse spot splice it then just stick it ?
