How is the NW TB supposed to make tuning easy?
It looks like a nice piece of work but I cant even find a set screw like the stocker has! So it looks like the only way to adjust it for a large cam is to drill?
Anyone? Am I missing an adjustment somewhere on this thing?
The set screw is there, it just is in a different configuration than stock. Mounted on the car, it runs front to back. There is also a set screw on the side of the crank that keeps the adjuster from moving. Make sure you loosen it first and only tighten it back down a little.
Drill the blade to get the IAC counts just under 100 and then adjust the set screw from there.
Nick.
Nick.
