View Poll Results: Should i reuse my header gaskets
Yes
32
71.11%
No
13
28.89%
Voters: 45. You may not vote on this poll
Should i reuse my stock metal header gasket?
Originally Posted by y2k_ta
Gaskets are meant to be tossed....don't take a chance. Buy new gaskets. If this is your first f-body header install, then you'll soon find out why it's not worth the risk. Trust me, you won't want to have to pull them back off just to replace a gasket.
Originally Posted by blue01ta
If you choose to replace them make sure you get the factory GM gaskets.
I do beleive that once pressure has been applied to the gasket, it is going to leak no matter what if you re-used it, it may not be noticable, it may be noticable. I would buy new ones to prevent loss of horespower, having to replace them again.
Just don't use the paper ones. Every one I know that has used paper ones have had leaks. Just reuse the old, unless they were leaking before hand, or you damaged them somehow while uninstillation.
