Fully Welded TSP Duals
Old 02-02-2006, 12:24 AM
DOUBT IT's Avatar
Default Fully Welded TSP Duals
I'm gonna weld up my duals tomorrow, and was interested to see if anyone has welded the L1 to L2 pipe junction together. Seems like it'd make the exhaust system harder to get off. Of course, I'm not going to weld the exhaust to the headers, but I'd like to weld every other junction.
Has anyone done this?
I'd especially like to see responses from the people at Texas Speed.
Thanks in advance.
Old 02-02-2006, 08:58 AM
777's Avatar
Everything is welded on my car. The exhaust shop actually got part of the driver side headers too I think
Old 02-04-2006, 01:00 AM
DOUBT IT's Avatar
Well, I welded everything but the L1 to L2 connection, and when we went to put it back on the car, we found that with antiseize on the inside of the pipe and the outside of the header, the damn thing slid right on. I still have the clamp at that connection for now, but I'm gonna take it back off and weld it soon.
Cliff's notes: The TSP Duals can be fully welded and slid on as one piece.
Old 02-04-2006, 01:21 AM
JEB Garner's Avatar
Bolted at the collectors, every other connection is welded. That makes each pipe one long continues pipe from the collector to the the exhaust tip. It stops any rattles before they can start. Welding also seems to help in holding down pipe shacking and those long continues pipes makes for a great sound.
Old 02-04-2006, 03:56 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I had one that was like that too. Head swap was a pita because of it too.
Old 02-04-2006, 11:52 AM
S1LV3R's Avatar
I had the TSP Y-pipe fully welded. That SOB didn't want to come off. If you look at the headers the driver side points out toward the door and the passenger points straight back. If you take into account that they're slid on pretty far and also pointing away from each other(header collectors) you can see how this would bind up. It's doable but be ready for a wresteling match when it comes time to take them off.
Old 02-04-2006, 08:39 PM
Full-Force's Avatar
when i build duals that im not gonna have to ship i weld the entire system up
you get both sides started on the headers and while pushing the exhaust toward the headers you move the system side to side and "walk" the pipes up on the headers
it makes removing and installing the exhaust a 5 min job
Old 02-05-2006, 01:34 AM
DOUBT IT's Avatar
I found this out when I slid them back on. I plan on welding the last joint when I drop the exhaust to take the tranny out for the converter install.
