2.5" or 3" true dual ?
2.5" should suffice for well up to 500hp ... and would have more efficient scavenging at lower rpm's due to the higher exhaust velocity. That being said ... 3" duals sound mean as hell and have a real nice deep throaty growl to them. So if you didn't need the extra ground clearance I'd go with 3" for the sound alone.
I agree. Alot of people have not noticed but I have. If you notice, the exhaust for mustangs 5.0 and 4.6 engines most all of the time have dual 2.5 exhaust and also most all of the time have 1-5/8 headers. Now most all headers for the F bodies both LT1 and LS1 use 1-3/4 headers. The GM engines obviously make more power and benefit from 1-3/4 and even larger headers. It only seems logical that the exhaust system itself would be larger.
I think a dual 3" system is the only way to go on these cars with a minimum of 1-3/4 header.
heh bigger is not always better guys a full 3" pipe will likely lose you a lot of low end torque on a car that doesn't really need it.
Here's a real good diagram to check what you need (wish the numbers went higher though):
http://www.dynomax.com/techsupport.stm
according to this, a 427cid motor making 500hp only needs dual 3" pipes, I doubt most of our cars need anywhere near that big.
How fast or what kind of power are you planning to run in the future? The fastest that I have ever run with my 2.5" duals is 10.40@130, car runs 10.1 with open headers. Back when I was running just bolt ons and a 150 shot, the fastest the car ever ran with them was 11.2, same set up ran 10.95 with open headers. I'd say if your looking to push 400rwhp or more in the future go with the 3". And these days, that number is easily acheavable with just a cam.
