Band Clamps
Old 02-05-2006, 01:54 PM
99M6Z28's Avatar
Default Band Clamps
TSP sent two pre formed band clamps for their ORY-pipe to connect to my new pacesetters. I am wanting to buy 3 more to use on the y-pipe its self and I am not sure which ones to buy? Do I buy the 3 inch or what. The y-pipe in 3 inch. I am getting the pre formed ones so that is throwing me off.
Old 02-05-2006, 03:08 PM
T-maxx's Avatar
Yes, 3 inch. Band clamps are a close 2'nd to actually welding the exhaust together. They also allow you to take off or re-adjust things later on. Don't forget to cut the bolt ends off when your done, that makes for more ground clearence. The drivers side header primary clamp has nowhere to go but down so cut it off while your under there. PM me if you want more info. I just did this not too long ago.
Old 02-05-2006, 03:16 PM
99M6Z28's Avatar
Thanks for the info
Old 02-05-2006, 03:20 PM
T-maxx's Avatar
What cat-back do you have? That is one of the biggest headaches when doing a TSP ORY install.
Old 02-05-2006, 03:28 PM
99M6Z28's Avatar
I currently have the Borla adjustable but that may change after I hear it with ther long tubes
Old 02-05-2006, 03:34 PM
Viper's Avatar
NAPA carries decent band clamps, TORX model.
Old 02-05-2006, 10:26 PM
wrencher
wrencher's Avatar
Yup those things work good..
