Mufflex Bump-Stop
Mufflex Bump-Stop
I installed the mufflex bump stop on my car and it stoped the bumping. But here is what I discovered: when I installed it where the instructions stated and when I put the clamp on the pipe and I tighten it, it was still loose. I did a "jale chicano" (what we call making it work in El Paso) and like I stated the y pipe does not bump any more.
I am assuming that the y-pipe that came with my 99 T/A (bought it used) is not the stock y-pipe for two reasons:
1. it has no flat areas on it
2. it was bumping (I assume the factory one did not bump)
Here is the question I have: does any one make a 2" y-pipe?
by the way I ordered the 2 1/2" bump stop from thunder racing.
Just curious if anyone has had this problem.
