FAST 90mm TB worth it?
FAST 90/90 is good if you have a cam/heads/headers where the extra air is needed. Other wise, go with the FAST 78mm intake and a ported TB. If you have a stock intake manifold, the FAST 90mm TB won't fit. you have to have the 90mm intake also. If you end up going FAST 90/90 you'll probably want an 85mm MAF also.
