What size is OEM LS1throttle body?
Old 02-20-2006, 04:25 PM
gollum's Avatar
Default What size is OEM LS1throttle body?
Is the LS1 throttle body 85mm?
Old 02-20-2006, 04:28 PM
Bombguy99z28's Avatar
78mm I believe.
Old 02-20-2006, 05:08 PM
Moderator
davered00ss's Avatar
78mm
Old 02-20-2006, 06:44 PM
v8hunter's Avatar
I thought it was 75mm necked down to 71mm (that's why you port the throttle body). Are you guys 100% sure it is 78mm.
Old 02-20-2006, 08:32 PM
SSPerformance's Avatar
Originally Posted by davered00ss
78mm
Old 02-20-2006, 08:43 PM
Formula-T/A's Avatar
Im pretty sure your right. I always heard it was a 75mm.
But hell I could be wrong.
Old 02-20-2006, 08:53 PM
camaroextra's Avatar
what i heard was 75mm with a 70mm neck.
Old 02-20-2006, 09:19 PM
2xLS1's Avatar
It is 75mm behind the plate and 73mm across the ridge in front of the plate measured with calipers.
Old 02-21-2006, 08:38 PM
Bo White's Avatar
Yes, 75mm. Blade measures 2.953"
Old 02-21-2006, 09:15 PM
what about the bottle neck?
