Fuel rail assembled how?
Is the stock LS1 fuel rail brazed or silver soldered together? I plan to remove 2 end caps and install -6AN fittings, then block the original inlet pipe.
In my opinion, if thats the direction you want to go it, get a aftermarket set, less headache and they will look alot better.. but its like anything else, if you really wanted to, it can be done..
same here, after market usually allow more volume and have more option potental. by the time you tig weld the stocker, between down time and price you could have bought a new better looking rail.
