how to adjust the throttle body cable?
i have a 01' z28 w/ trac cont. and cruise, i put on an 80mm bbk tb and the throttle cable is loose (just a lil slack) is there a simple way to take the slack out. i havent looked in the box behind the bat. yet. i think i will have way better throttle response and mabe it will open the tb more. thanks
Moderator
Snap-clip adjusters on the cruise-TCS and TCS-TB runs.
You may also have slack in the pedal-TCS run which is
not adjjustable, you will either have to bend the pedal
arm or insert a spacer (up to 1" may be needed to get
it to pull full open, at the floorboard).
