What size for custom dual setup?
2.5" will be fine unless you plan to make, what is is, >450 rwhp in the future.
Leaving that possibility open I would go 3" unless you are lowered, in which case I would return to stock ride height and go 3". Suspension geometry is a little off when lowered, and you might want to do something fun like spray it in the future.
If you're using an X crossover, you want the crossover diameter to match the header collector size. IE - 3" collectors, you would run at least 3" to the X. You can reduce after the X if you want.
This is what Dr. Gas recommends with their X.
