dynomax bullet muffler help quick!
hey guys i am on summits website right now about to order a bullet. i just have a few questions before i order. They have 2 1/2 inlet/outlet, 2 1/4 inlet/outlet, and 3inch inlet/outlet. For the length they have 16.5in and 23.5in. my question is... what is the best size to go with the stock exhaust i have now? also is it better to have the longer one? i was going to get the bullet welded on and cut the stock muffler off and weld a pipe in place of it to keep the stock tips on each side. help asap please
That's what she said...
The flow is only 1 in and 1 out on the bullet, you would have to put it in the I pipe for it to work properly. The longer one is going to dampen the sound a bit more, but also be harder to fit in the system. You would have to do some wierd **** to make that muffler work with the stock i-pipe, if you plan on having exhaust gas coming out of both tips.
I would look into buying the TSP rumbler cat-back, its cheap, and basically the same thing.
i was going to put it where a cutout would go....before the axle..... and have them fab up a customer y connector to keep the dual tips
