which underdrive pulley? ASP or SLP
Old Mar 22, 2006 | 08:41 PM
383camaroSS's Avatar
Default which underdrive pulley? ASP or SLP
which pulley is better over all? for nitrous heads and cam?
Old Mar 22, 2006 | 10:41 PM
REDWS6ROCKET's Avatar
asp here!
Old Mar 22, 2006 | 10:46 PM
just-a-z's Avatar
SLP here. I think they are both right up there as far as quality goes
Old Mar 23, 2006 | 07:05 AM
slow trap's Avatar
asp here as well.you shouldn't have a problem out of either if your tensioner is good.
Old Mar 23, 2006 | 07:43 AM
KILLERARMY's Avatar
  • Extra-tall belt-retention "walls"--no more thrown belts!
  • No aftermarket tensioner required
  • 100% steel construction
  • Lighter than the stock balancer
  • Integral timing marks and puller-mounting threads
  • Keyed for high-rpm or supercharged applications
  • Does not cause false knock retard or erratic power-curve dips
  • Includes a new balancer bolt
  • This is what you need to know about SLP Pulley
Old Mar 23, 2006 | 09:17 PM
WILWAXU's Avatar
Untill the factory tensioner wears out
Old Mar 23, 2006 | 10:13 PM
DocEwww's Avatar
ASP here w/ Katech tensioner...I'd avoid SLP just for the name alone
Old Mar 23, 2006 | 10:57 PM
Rescue Ranger's Avatar
I went w/ a March pulley. Honestly after reading night after night about heads, cams, and clutches, I just picked one off of BYUN's site.
