Underdrive pulley
Old 03-28-2006, 12:07 PM
tcossair's Avatar
Default Underdrive pulley
Part of my new trans am purchased included an slp underdrive pulley. How hard is the install and any cons of installing it?
Old 03-28-2006, 03:14 PM
Z28LS1camaroguy's Avatar
its a good underdrive pulley alot of people on here have that pulley, i am gonna get the same one here soon. ASP is the pulley that seems to throw belts for some guys, and its easy to install just get a three point pulley puller and a new crank bolt and you will be set. there are tons of writeups for it aswell.
Old 03-28-2006, 05:21 PM
10 Second Fun Car
jlrz28's Avatar
Ive had my asp for 12k miles and no problems yet, I think they are better now than they were.
Old 03-28-2006, 05:28 PM
yeah but the SLP have the added assurance of the bigger lip on the outside of the pulley to keep the belts safe and secure on the pulley, not sayin ASP pulleys are bad but SLP has alittle more reliability so to speak.
Old 03-28-2006, 05:29 PM
slow trap's Avatar
if you have or plan to have a bigger sound system in your car the lights might dim some but unless you go very big you should be o.k does it have belts with it ?
Old 03-28-2006, 05:50 PM
HawaiianZ28Rider's Avatar
speaking of pulleys
is the underdrive pulley the only pulley that should be changed when it comes to modding? or are there other ones i should change?
Old 03-28-2006, 05:53 PM
you could change the alternator pulley if its an automatic to keep the volts up, the tensioner might need to be changed, but that keeps the stock pulley just different bracket. and the Idler pulleys like to squeek on these cars but thats an easy fix, only if the pulley squeeks of course.
Old 03-28-2006, 05:55 PM
Iron Sights's Avatar
Originally Posted by HawaiianZ28Rider
speaking of pulleys
The crank pulley is the one you want to change; some guys go with a smaller alternator pulley in addition, but it is easy to turn in the first place (most of the gains come from the smaller crank pulley, anyway).
Old 03-28-2006, 08:44 PM
tcossair's Avatar
Kewl, thanks guys. Now I need a bunch of free warm weekends to do this and other small jobs. The prevous seller gave me new belts and the pulley, but not sure about a new crank bolt. Is that something you only can get at the stealership?
Old 03-28-2006, 09:30 PM
yup sure can, or you can order one from one of the shops on the right column.
Old 03-28-2006, 09:53 PM
exstanger's Avatar
Why do you have to use a new crank bolt. The stock one is not a Torque Yield bolt or so I've been told.
Old 03-29-2006, 12:50 AM
rjkZ28's Avatar
yea i have the asp one now for about month and so far no probs. mine came with a bigger alt pulley, so i put it on, but now my volts drop near the top of red. so after i go to the track on sunday im gonna install my stock alt. pulley which is way smaller then the one that came with the asp crank pulley.
Old 03-29-2006, 08:23 AM
tcossair's Avatar
Seems the seller also provided a large bolt, which I'll bet is the crank bolt. Even less effort for me to install it some weekend here, no more excuses. ;o)
Old 03-29-2006, 09:41 AM
FstBlkz28's Avatar
Not to hijack the thread, but can we fit a 3-ton 3-arm puller on the pulley with the radiator/fan in?
I used one to pull my pulley when I installed my cam, but that puller is a big sonofabitch and it seems like it might not fit w/ the whole radiator/fan setup in the car still.
Old 03-29-2006, 10:21 AM
3-ton pulley puller why do you need one that big??? but if you have taken a pulley off before with it then i guess use it, but you most likely will have to take the radiator and cooling fans off.
Old 03-29-2006, 10:22 AM
And the crank bolts you can only use once, so your best bet will be to use the new one.
Old 03-29-2006, 11:22 AM
FstBlkz28's Avatar
I tried to use a 2-ton puller this past weekend and it got completely OWNED by my pulley
Old 03-29-2006, 11:24 AM
BIG_MIKE2005's Avatar
You could always get the Powerbond pulley from TSP. Its the same freakin pulley as SLP just without the logo & price increase.
Old 03-29-2006, 11:39 AM
ski23's Avatar
yup, got my powerbond from tsp. thanks BIG_MIKE
Old 03-29-2006, 11:48 AM
02SS:ZEUS's Avatar
I've had an ASP pulley for about 6 months now. The belt started squeeking once so I popped the hood to check it out...the accessories belt was half way of the pullies. Its the only time its happened, we'll see if it happens again. If it does, I might switch to SLP.
