fast 90 throttle body questions
Old 04-05-2006, 03:52 PM
98transguy's Avatar
Default fast 90 throttle body questions
just got fast 90/90 combo installed on car. tried to start car today and it has trouble getting it to idle. have to give it gas for a few seconds before i can let go and have it idle. does it every time after i shut off car and try to start it again. i heard something about drilling a hole in the blade of the throttle body? could this be a reason it wont idle? opinions?
thanks guys
Old 04-05-2006, 04:27 PM
CRL 01 SS's Avatar
You need to drill the hole bigger in the TB blade to let more air into the engine at idle.
Old 04-05-2006, 04:28 PM
98transguy's Avatar
what size does it need to be drilled out to? and if they know this problem why doesnt fast drill the hole larger to begin with?
Old 04-05-2006, 09:14 PM
Detroitmuscle's Avatar
Drill a small hole, can be even smaller than the one in the stock TB and you should be fine.
Old 04-05-2006, 09:21 PM
TryingT/A's Avatar
That seems like the problem with fast. The suction over the blade causes the blade not to close while the car is running. Some drill a hole, some mess with the screws. Slow Trap resolved his issue by putting on a return spring on the t/b. Someone did that but couldn't get 100% throttle due to a heavy spring.
I would resort to drilling last. will post the link if I find it
Oh yeah, hole size drilled is usually 1/8 inch like the stock (I think)
Old 04-05-2006, 09:24 PM
TryingT/A's Avatar
Here's the link
https://ls1tech.com/forums/showthrea...sticking+blade
Quick Reply: fast 90 throttle body questions
