Bolts on suncoast creations air intake box
Old 04-10-2006, 12:31 PM
98Z28MASS's Avatar
Default Bolts on suncoast creations air intake box
hey everyone, I have the suncoast creations ram air box, and I went to try and remove the k&n filter and the two top bolts wont come out? Its a plastic intake box so I dunno what happened but the bolts will turn, however they just wont back themselves out of the holes. They just keep turning and not backing out at all. I didnt overtighten them either when I first install the system. Should I just grab my dremel and cut the heads of the bolts off? Any info or suggestions would be great! Thanks in advance!
Old 04-10-2006, 12:55 PM
Detroitmuscle's Avatar
Same thing happened to me but I switched to a lid before I tried to remove the filter.
Old 04-10-2006, 02:30 PM
98Z28MASS's Avatar
Did you just cut away the whole plastic airbox or did you rip out the k&n because the mounting bolts are below the k&n...Im so pissed, its rediculous that that happens, like what you arent supposed to change/clean your air filter?????
