What to do with the rear O2s ???
Im installing headers and well there are 4 O2s and I got two extensions for im guessing the front ones. But what do I do with the rear O2s?????
Well, while on the topic of rear 02's, I just got my Kooks Catted Y today,and it had bungs for the rear 02s. After reading the "EGR - AIR - O2" sticky, is there really a point to hook them back up? Or should I just plug the bungs and have them tuned out? Will the stock rear sensors reach back to the Y with no extensions if I need to hook them back up? Since it looks like they will set a code even if I connect them, may as well not even bother ya know?
Like I said they don't do anything really besides tell the computer your cats are working. The front o2s are the important ones.
I'm installing my Pacesetter LTs this weekend and will have them tuned out by Sunday.
I re-installed my rears. No extension was required. If they ever fail I will have the code deleted at that time. I figure I may as well keep them there in case I'm unlucky enough to run into a thorough inspector.
The fronts are my concern. A week after installing headers I'm getting the dreaded insuficient switching errors (p1133,p1153.)
...no codes from the rears though.
I bought a couple of plugs for the rear bungs on my catted-Y at autozone. I think there were actually oil drain plugs, you can find the tread pattern using search. I also run O2 sims in the rear, not SES lights since.
after getting the rear O2's tuned out w/ LT swap and then when it's time for a smog (which i plan on swapping my shorites and cats back on w/rear O2's) will I pass the tech's computer?
That's what she said...
Originally Posted by ~ever~
Hey guys should I replace the O2s ???
Mine looked preatty black.
