Help car keeps blowing fuel pump fuses
Posted this in fueling and injection with no replys so im going to give it a shot over here
Ok the car is a 98 Z. It has a walboro 255. I had the problem with the hose poping off the pump last week. I fixed it and it ran fine for like 3 days untill last night when the car shut down. I thought it was the same problem but it wasnt. I couldnt hear the pump prime so I checked the fuses and the fuel pump fuse was blown. I replaced it and as soon as I would turn the key to the run position it would blow the fuse. Any ideas, common problems/pinch points for the wiring.
Short in the pump circuit or the pump itself.
Remove the relay and ohm out the circuit (test for continuity);
unplug connector from pump, ohm out the pump (test for continuity);
did the pump overheat...?
Pump shouldnt have overheated I had over half a tank. Let it sit for a half hour before I tried the last fuse. How would I ohm out the circuit or the pump. I suck at electrical ****. Thanks for the reply
pull the relay, observe the pinouts labelled in the relay socet and match them up with the wire diagram;
with a digital multimeter, set the DMM to "continuity beeper" mode and probe the ground pin and the pump circuit pin in the realy socket; if the continuity beeper beeps, then you got a short; also check like this between the pump circuit pin and chassis ground;
this will just tell you if you have a short downstream of the relay;
if the DMM beeped at the relay, then you have to disconnect the connector at the pump and probe it for continuity; if the DMM beeps, then the pump or its subwiring is shorted; if DMM did not beep here but beeped at the relay socket, then the short is between relay and pump.
Process of elimination.
If you don't have a DMM, you could use a test light, connect one end to battery positive, probe the pump ciruit pin in the relay, if it lights you have a short to ground; same thing at pump connector.
