exhuast will not slip over my header collector
By comparing them to a 3" piece of pvc pipe I had laying around I was able to determine that it is actually the collector that is mishapen. This makes sense since the duals were packaged nicer than the headers. I guess I'll just squeeze the collector a little.
For future reference OK 4wd seems to be the only place in jersey with a 3" or larger pipe expander.
Yup, just have an exhaust shop expand it slightly. Measure how much bigger you'll need it and let them know. Should only cost a few bucks, if anything (some shops around here are nice enough to do it for free). Just make sure they're gentle with it and don't expand it too much, otherwise it will start to rip down the sides.
It hardly needs to be any bigger. If they were both perfectly round a little lube would allow them to slide together. I'm going to first try to get the collector as round as possible. Also once I do get them to fit, should I use anything on the joint under the band clamps?
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
if u have had to force it on, it will not be perfectly round probably..get them welded if this is the case..You could use exhaust tape but i wouldn't.
That's what she said...
Originally Posted by slowscott
http://memimage.cardomain.net/member_images/5/web/689000-689999/689287_44_full.jpg
As you can see, OK was only able to expand the first half of the flange. Will this be enough for the TDs to fit right? or should I cut it and take it back?
