Needing QTP instructions/wiring HELP!!
Bout ready to pull my hair out here over the electrical cut out wiring guide. Does anyone have the QTP instuctions on how to wire this damn thing to a switch OR can someone show me a way/picture that I can hook it up to a switch? I really need to get this cutout capped before tomorrow.
Are you not running the switch that the QTP electric cutout came with? The switch that it comes with is very easy to wire up. You just have one black wire that you run to a ground, red wire w/ a fuse that you run to the IGN spot in the fuse box, and then a male to female adapter that you plug in.
