FLP custom true duals
Old 08-10-2006, 01:13 AM
LS1-Mike's Avatar
Default FLP custom true duals
Well, I just installed some QTP headers and had Finish Line Performance custom fabricate 2.5" true duals over the axle and out the back. Thought I would share some pictures.
The system is 100% stainless steel and mandrel bent. I used magnaflow 3" cats (94109) and magnaflow bullet mufllers. Reused my dual/dual tips from the loudmouth system I had before. Band clamps connect the system to the header collecter and the system uses an X type crossover.
The biggest problem FLP ran into was getting aroung the 3-point SLP subframe connecters on the drivers side. I believe it required an 80 degree bend.
It sounds mean at WOT but docile when cruising. Very expensive system ($1400), but worth it.
Here are some pics. Enjoy!
http://i112.photobucket.com/albums/n...Exhaust001.jpg
http://i112.photobucket.com/albums/n...Exhaust002.jpg
http://i112.photobucket.com/albums/n...Exhaust005.jpg
http://i112.photobucket.com/albums/n...Exhaust003.jpg
http://i112.photobucket.com/albums/n...Exhaust006.jpg
Old 08-10-2006, 01:53 AM
SS4Luck's Avatar
eeek thats a lot of $$ but worth it if you like it i guess
Old 08-10-2006, 09:34 AM
John Milner 810's Avatar
awesome.
can we get a sound clip, i bet it souonds real good
Old 08-10-2006, 10:44 AM
Wyckedcamaro's Avatar
dont frett.. mine cost me 1500 without the headers.
Looks good.. Any reason you didnt go x or h pipe?
Old 08-10-2006, 11:34 AM
LS1-Mike's Avatar
Thanks everyone. Well, I asked for an X pipe set up and thats how they fabbed up the junction. Will this X-type crossover flow as well as a true X-pipe or H-pipe?
I'll try to get some sound clips up
Old 08-12-2006, 07:23 PM
LS1-Mike's Avatar
Will this system flow well without a true X-pipe? Like fromDr. Gas or magnaflow for example.
Old 08-12-2006, 09:10 PM
DanZ28's Avatar
I'd think that yours would work more like an H-pipe, not really an X-pipe as far as i can see. For $1400 I might ask FLP if it matters or not, but for that money I would of made sure it was something like a Dr. Gas X-pipe, not the standard one, but the one they make that is more straight in and out for true duals out the back like yours. Looks nice otherwise though.
Dan
Old 08-12-2006, 11:08 PM
LS1-Mike's Avatar
Thank you for the input. I will be talking to FLP about it sometime this week.
ANyone else have any input on this?
