People with WS6 air box and FTRA/SSRA
Old 08-13-2006, 10:49 AM
Louie83's Avatar
Default People with WS6 air box and FTRA/SSRA
How did you cover up the opening in your larger WS6 air box for the FTRA and SSRA?
Old 08-13-2006, 11:04 AM
The1N_only's Avatar
for the money, its not really worth it to buy either the FTRA or the SSRA because of the gap.... the old BG ram air was the was to go for ws6's but they are no longer made
Old 08-13-2006, 12:03 PM
Louie83's Avatar
So what you are saying is that they do not make anything to cover the large gap of the WS6 air box, making it not worth the FTRA/SSRA?
If that is the case, then I will just buy a regular airbox.
Old 08-13-2006, 04:25 PM
The1N_only's Avatar
what im saying is if you had a ws6 air box already... i would spend the money on something else... something like a pully.... to me you get more bag for your buck
Old 08-13-2006, 05:16 PM
Tech Resident
ChocoTaco369's Avatar
http://www.ls1speed.com/catagory.cfm?catagory=Induction
scroll to the middle of the page for the BG system.
Old 08-13-2006, 05:26 PM
The1N_only's Avatar
you can only buy the replacement parts... you can no long buy the whole kit... you might be able to peice it together
Old 08-13-2006, 05:30 PM
Louie83's Avatar
I thought the Big Gulp was designed for Camaros and only Camaros.
Old 08-13-2006, 05:31 PM
chrs1313's Avatar
just get a stock air box and get a ftra/ssra it is worth the money has been proven many times, same reason i made my ram air intake to mimic it just to the max of like 3.5inches, also look at times for proof
Old 08-13-2006, 05:34 PM
The1N_only's Avatar
to each its own, but all im saying is for the money i would perfer to have an under drive pully then getting a non-ws6 air box then install the FTRA/SSRA just my .02
Old 08-13-2006, 05:39 PM
Louie83's Avatar
I see what you are saying, and I'm not ruling it out. I just research and go back and forth a lot before I make a decision. And the UD pulley will be on the way shortly.
Would it make any sense to keep the WS6 box, get a SSRA, and not block off the air box opening?
Old 08-13-2006, 05:44 PM
The1N_only's Avatar
there is alot of people that just dont recomend it.... but you'll still gain some mph on the big end... Me i would spend my money on something else unless you looking for every last HP
Old 08-13-2006, 06:09 PM
WhiteStripes's Avatar
Wait, your car dos have a WS.6 hood right? If so just debaffle it and call it good. That's just as close to ram air as those other kits, and it's free. Like previous posters have said, there are better things to spend your money on.
Old 08-13-2006, 08:03 PM
Louie83's Avatar
I have the Firehawk hood.
Old 08-13-2006, 08:13 PM
02SOMWS6's Avatar
So just cut out the baffles built in the hood so it is direct from the opening to the air box. I have a SLP Ram Air HO hood and just cut awayYou can see into the airbox with the hood shut. The car makes a hell of a sucking noise. So many people think it's supercharged when I roll by. It's worth it to do the mod.
Old 08-13-2006, 08:16 PM
Louie83's Avatar
Alright, will do.
Old 08-15-2006, 03:48 AM
WILWAXU's Avatar
I didn't cover my WS6 lower up. I left it open.
Old 08-15-2006, 06:33 AM
BENZTECH's Avatar
If you remove the baffles will rain water get into the intake? I also have a firehawk And have wanted to de-baffle the opening but I live in florida & it rains often.
Old 08-15-2006, 09:36 AM
Dal1as's Avatar
You shouldn't have an issue. I have mine sealed with no baffles and have gone through some pretty bad thunderstorms. Filter gets a bit wet but no moisture gets through. You may want to go with an oiled filter if you do it though.
Old 08-16-2006, 06:48 AM
BENZTECH's Avatar
Thanks Dal1as I do have a k&n filter, and will be debaffling the hood
Old 08-16-2006, 07:24 AM
1QUIKWS6's Avatar
I think your original question was something along the line of the pic below? When I had the FTRA I made this block off plate from stainless, polished it, and it riveted in from the inside.
I have since switched to the Volant CAI with a debaffled hood and made custom ducts to force the air directly from the hood nostrils to the sealed Volant box.
-Jay-
OLD:
NEW:
Quick Reply: People with WS6 air box and FTRA/SSRA
