Is the F.A.S.T. 90mm intake worth it?
Old 08-22-2006, 05:21 PM
blown00ls1's Avatar
Default Is the F.A.S.T. 90mm intake worth it?
Ok so I want to upgrade my intake, i have an 00 LS1 which I am told has the LS1 intake as opposed to the LS6. I would like to change this, as well as the throttle body and I read in hot rod mag i believe that you can gain about 30 RWHP from it. But, what i am wondering is, is the f.a.s.t worth it or not? It's like 1100 dollars to get the nick williams 90mm and the fast intake whereas I can pick up an LS6 for like 400 tops and then port my tb? would the gains be nearly the same? or should i just fork out the cash for the f.a.s.t. with the nw tb?
Old 08-22-2006, 05:37 PM
seadonky's Avatar
not unless you have heads/cam/no2/
IMO... ls6 intake will hold just fine.
Old 08-22-2006, 05:42 PM
Andrew1989's Avatar
It all depends on what is done to your car. I have heard that under certain scenarios the 90/90 setup can actually cause a power loss, but i believe that was for bolt on cars. If you have a H/C car or a power adder it would show gains over the LS6.
Old 08-22-2006, 05:46 PM
blown00ls1's Avatar
The car currently has an ATI procharger as well as 55lb injectors, so i should go with the f.a.s.t.?
Old 08-22-2006, 10:47 PM
AINT SKEERED's Avatar
nope , stay with the ls6 with the procharger. you are forcing it through.
Old 08-22-2006, 11:56 PM
Andrew1989's Avatar
Yeah, the f.a.s.t. will leak from FI
Old 08-23-2006, 12:31 AM
The PAT WS6's Avatar
unless u got money to blow then yes, i would jus go with an ls6 cus its cheap and u would only gain a couple hp with lsx
