How hard to install TB?
Old 09-09-2006, 01:07 PM
wldesyWS6's Avatar
Default How hard to install TB?
im wantin to buy and put in a P&P TB in my WS6, so i was wondering how hard that is, it doesnt seem very hard, but are there sensors or anything that may get messed up, b/c a buddy of mine has a BIG issue with his sensors in general on his car thanks guys
P.S. anyone w/ a P&P TB for sale shoot me a PM
Old 09-09-2006, 01:11 PM
WhiteStripes's Avatar
If it's a stock P&P unit like from TSP it a matter of detatching the throttle cable, the TPS, the other little wire harness on it etc etc, then unscrewing it, and you may as well do the TB bypass while you are at it.
Old 09-09-2006, 01:13 PM
As for the sensors, obviously make sure the keys arent in it or anything, you could even detach the battery cable to make sure it doesn't detect that you detached anything. Can't hurt you know.
Old 09-09-2006, 01:33 PM
wldesyWS6's Avatar
how do do TB bypass and how difficult? not exactly sure what it is.....
Old 09-09-2006, 01:39 PM
phatkat's Avatar
http://www.installuniversity.com/ins...sity/index.htm look under install documents and it has both the TB install and the TB bypass.
Old 09-10-2006, 09:01 AM
SSDoubleK's Avatar
Easy stuff, archives have plenty of info. on this.
Old 09-10-2006, 12:29 PM
wldesyWS6's Avatar
ive heard that you gain 5 hp or so from a TB bypass, but (this is no ****) i heard some1 say that you actually lose performance in the 1/4 mile, so is that BS or what?
Old 09-10-2006, 12:54 PM
98hardtopZ's Avatar
how would you lose performance and gain horsepower? this doesnt make sense, the only application in which a gain of horsepower would hinder performance would be a gain of so much that your tires wont stop spinning...
Old 09-10-2006, 02:18 PM
Danny2tek's Avatar
The only problem you might run into is if the TB is from a different year, the TB shaft might be smaller/larger. If thats the case all you have to do is change the shaft.
Old 09-10-2006, 04:20 PM
SIC LSX's Avatar
5 mins
Old 09-10-2006, 04:40 PM
Wilkenstein's Avatar
How would I go about doing this? My freind lent my his old tb and after having it ported I realized it wouldn't work. Got it on the car and wondered why the plate wasn't closing all the way. Touche tb.
