need help finding a part number for a oil pan bolt
hey guys i have a 2002 ws6. I need one of the part numbers for one of the oil pan bolts, that i broke awhile ago and now with the motor out i can finally change it. most of the bolts are the same, but in the back of the oil pan there are 2 longer skinny bolts that go through the oil pan and bolt up into the motor. i have tried to find the part number for them, but no luck was found. does anyone have an idea as to what the part number is? thanks for the help
Jon
Jon
For any and all gm part numbers check this thread first:
https://ls1tech.com/forums/general-maintenance-repairs/336981-lt1-lt4-ls1-ls6-f-body-part-numbers.html
if you don't see what you need there then ask in this thread:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/336996-request-part-numbers.html
