Katech new product release: Oil Cooler Adapter
Adding an oil cooler to your racecar? Upgrading your existing cooler? This compact, billet aluminum adapter allows you to utilize the ports already cast into your existing LSx block to plumb your cooler with AN -10 lines. When used with the Ron Davis radiator, this reduces backpressue to get more pressure to the engine. The adapter has clearly labeled IN and OUT ports and laser-etched logo. Careful consideration was taken during design to accommodate existing wiring harnesses and other objects in that area as well as fit with full length headers installed. The result is an attractive adapter that maximizes available space. Uses M6 x 1.00 x 45mm bolts and production gasket (included)
KAT-A4722 Oil cooler adapter kit
- AN -10 Fittings included
- Gasket and bolts included
$89.95
KAT-A4726 Oil line kit for C6 Z06
- Goodridge cloth hose
- Heat shield sleeve included
- Ready to install
$279.95
1-1CV06E Ron Davis Radiator for C6 Z06
- High performance radiator with integral oil cooler
$1293.85
$89.95
- Ready to install
$279.95
$1293.85
Sorry to dredge this back up, but why do you tap the IN port? For comparison, Lingenfelter taps the IN port while DRM taps the OUT port. All things being equal, shouldn't you be getting temperature readings from the hottest oil in the motor, i.e. the oil going OUT to the cooler?
Just asking. Thanks,
-ch
-ch
-ch
-ch
Good point. I would say tap the out port also, but it is a matter of preference I guess.
-ch
-ch
