custom true duals??
custom true duals??
ive gone to several local shops and they have all told me the same thing, it is impossible on my car. well you and i both know its not and i tried telling them that but if they dont think they can do then i dont want them touching my car. so what are my other options? ive browsed through the td stickie and even searched but i havent quite found was i was looking for. my question is this, if i had a lift, mufflers, xpipe, and assorted tubing how hard and would it even be feasable sp? to do it myself? any opinions/comments are appreciated... oh yea, if possible i wanted 3 inch over axle...but ill settle for 2.5 if i had too.
That's what she said...
Originally Posted by RrCoX22
4" pipe huh... that's intense... hope your not dropped that much
Took me forever and a million years, but it's the epitome of high and dry.
https://ls1tech.com/forums/generation-iii-external-engine/565945-3-ory-4-i-pipe-cutout-into-slp-dual-dual-pics.html
Originally Posted by 98hardtopZ
oh yea forgot one thing, if i lower my car will 3'' be ok or will i scrape every speedbump i approach...
wait, is blurls1's name casey?
...the two common sponsors in this section are casey and jordan (at least at night) orangapeel being the other (jordan) = newb mod
the reason i asked is b/c my name is casey...i saw that post and instantly was "holy **** how does this dood know me?"
98hardtopZ- We used the flowmaster u-fit 3" exhaust. If you go under the axle it fits great and has all the pipe and bends you'll need. I don't have pics up yet, but it tucks well and looks great. Find a friend who can weld and you're good to go. Flowmaster offers the u-fit in 2.5" also and both come with an h-pipe. I don't think either has enough of the right bends to go over on our cars. As an aside, the 31" Classic Chambered muffler will fit under our cars too.
well ive got 3" true duals that dump before the axles and at the end of the dump i believe i am 3.5" off the ground and i also have the SLP LT's. but with a 3" setup i dunno if its dif on camaros but it must be BC blur said that hes 5" off the ground, then the maros must have better ground clearance!!
We do have beter clearance....I've got trues with an x pipe, borla xr1s dumped at the axle and can go over speed bumps and pull in my driveway without coming to a complete stop...my buddy has a similar setup(without the x) and hits everything he comes across...his is a 2002 ram air,,,,,,,,my .02
