filter-like oil caps?
i have seen in a few pics of engines what looks like an oil filler cap that is a filter. can anybody explain this? i'll try to post up a pic if i can find one.
i just ordered one from speed inc. i want to be sure no oil comes in contact with my new tb, or my new fast 90. and my oem oil cap has issues (think the o ring swelled) so it was time for a replacement of some sort.
I had a question about these if i run one of these do i have to block of my pvc hoses? If so do i have to block off the two in the back and one on the passanger side? Sorry to jump in with questions, but i think this may be great info for you as well if you are thinking about putting one of these of these on as well. thanks
Kleeborp the Moderator™
You don't have to block off anything to run this breather filter.
Now, keep in mind that you can either put it in the existing black plastic chimney that the current cap goes in, or you can take the valve cover off, remove that plastic piece, and it'll fit right in there (it kinda screws in just like the black chimney).
