K&N and MAF question
as for SLP MAF... i think it was a waste of money, try to sell it on ebay and get your money back IMO
i dont think anyone should ever buy a aftermarket MAF, when you have your car tuned you can have your MAF deleted and run a SD tune, its what i did
You will however still need the adapter harness. Im sure you can track one fo those down...or do like mentioned above and find the pigtails in a yard and make one.
Im ditching my SLP unit for the ls6 unit due to a P0103 that will not go away. I tried cleaning my filter and all...I just think its junk. Plus my tuner suggestsed ditching it.
Justin
k&n are expensive and junk. If you have one, then it's not doing any harm except to your wallet. OEM paper filters have been proven to supply enough airflow for 500bhp.
As for the MAF - yep total waste of money. Again a stock MAF is fine for well over 500rwhp. An no, it doesn not really affect flow, this is the funny thing with fluid dymanics. The air flow will increase in speed in a smaller area, but less area and high speed may well equal volume over time.
Aftermarket, MAF's make power by liying to the PCM which causes the car to run lean, thus a bit more HP. Tuning will acheive exactly the same result but under controlled conditions. Also if you mod your car a lying MAF will more likely hinder and run the risk of running too lean. So then you are forced to tune it, and in which cause it reverts to being a $200 mistake. No gain over a stock MAF. At 500rwhp you might see 3rwhp difference between a 75mm and a 85mm.
An SD Tune is speed density, you can physically remove the MAF or just disable it. It uses pre-defined MAP tables setup on a rolling road.
SD is good, but it then will ignore any future changes, forcing you to retune each and every time you change something. MAF's may be a PITA at times but they do have benfits and allow you to install nearly all the bolts and still have a car that runs well and safe without the need for a tune.
also, hypertech is garbage...you should research before you buy anything because you have purchased everything you shouldn't have. For the price of the hypertech adn slp maf, you could have gotten a real dyno tune which would have given you mroe power, safer and without any issues. Next your going to say that you bought 50 dollar resistor for the iat from slp.
K&N in an aftermarket lid vs stock in stock. That's honest.
I flow tested lids once, and paper filters vs open (no K&N handy).
All but a nit was in the lid (silencer) and the filter means diddly.
People do pick up long term drift in the MAF from oil depositing.
Good hygeine pushes out the inevitable but it's going to come.
You can clean it. If you use an oiled filter, make it part of your
filter maintenance regimen.
SLP MAF comes with half of Fernco hose P/N 1059. It's an odd
one that isn't going to be found at Ace / Home Depot.
Your adaptor, go to Casper's --> or the junkyard if you feel
more like soldering it up, truck pigtail to your MAF and IAT
harness wires.
SLP MAF with the screen is going to flow worse than a
descreened stocker. Or a descreened truck piece or a
screenless Z06. But these all have still a pretty close
resemblance to known good -and available- MAF calibration
tables. Descreened truck MAF and truck table worked straight
up for me.
LOL no actually i didnt get the resistor. i just dont know anywhere around me that does dyno tuning. I live in Lebanon, Va. and the closest that i know of "was" ride revolutions but i think that they closed down. if i did get the resistor it would give me at least 50 extra HP wouldnt it LOL!!! Just kidding!
