LPE 100mm MAF
LPE 100mm MAF
I did a search and only found one person running this. My stock MAF is maxed out right now. My options are the SLP 85mm or the LPE 100mm. I am thinking of goin with the LPE one because I am goin to add heads over the winter and I should be at 500HP then.
How would I attach this to the Lid and what bellow would I use to connect it to my 90mm T/B?
Originally Posted by DansRedz28
just go SD and get rid of the maff all together!
For higher power if you are making a good deal z05 works well and stocker is fine for 500whp and less.
Originally Posted by Josh
How are you maxing out a stock MAF with nothing more than a cam? Do you have any logs of that?
Josh
Josh
He isnt maxing the actual Hz out, he has a 90mm TB behind it I dont know about you, but running a 75mm maf in front of a 90mm TB is counterproductive.
