In the middle of Pacesetter Header Install.. How do I remove the damn dipstick??
Old 11-18-2006, 07:33 PM
CJDZ24_Z28's Avatar
Default In the middle of Pacesetter Header Install.. How do I remove the damn dipstick??
My SS is over my boy and fellow member here wilwhite2kss's house. Everything was going good for the most part until we got to removing the passenger side stock header because of the damn dipstick I did a search and even went to LS1howto.com and couldn't find to much help. Do we just yank on this damn thing or pull it straight up? Any help would be appreciated.
Old 11-18-2006, 07:36 PM
Keenov's Avatar
You need to remove the bolt and then pull it out. The bolt is 15mm, IIRC.
Old 11-18-2006, 07:46 PM
scof0elife's Avatar
I got it out. there is that one bolt then after I got pissed and jacked it out. luckly it came out whole hahaha. but now I can't take out the coil packs which covers the spark plug. how the hell did you remove those?
Old 11-18-2006, 07:49 PM
blkbird's Avatar
There are five bolts that hold it down to the valve cover. The last one is a PITA so when you put them back on, for future mods, dont put those ones in the back on again....
Old 11-18-2006, 07:52 PM
CJDZ24_Z28's Avatar
We took the 15mm bolt out but i didn't know if we could pull it straight out.
Well I learned the hard way on my 99 B4C. There are 5 bolts. The 1st couple of bolts you can get with a 10 deep socket. The the last 2 i used a open 10mm wrench. The 4th one sucks ***. You cant even see it. You just have to feel around for it and then use a open end wrench and loosen it.
Old 11-18-2006, 07:54 PM
CJDZ24_Z28's Avatar
Also like stated once you get them all off and are ready to put them back on only put like the 1st 2 or 3 back on so you don't have to deal with them again
