oil pressure gague
Old 11-25-2006, 08:44 AM
whiteLS1's Avatar
Default oil pressure gague
where do you hook it up? like an autometer gague mechancial or electric
thanks matt
Old 11-25-2006, 10:18 AM
LS69TA's Avatar
Above the oil filter, remove the small piece that's bolted onto the block with 2 bolts. Just remove and tap it, you'll see where the sending unit goes. I used a 45 degree elbow to give the sending unit clearance between the block.
Old 11-25-2006, 11:11 AM
Snuffles's Avatar
Here's thread from two weeks ago:
https://ls1tech.com/forums/generation-iii-external-engine/606446-autometer-oil-temp-gauge-install.html
That's where LS69TA is talking about and where I put mine.
I didn't use an elbow, however it was tight. A 45* isn't a bad idea.
Old 11-25-2006, 12:11 PM
RoastEmSS's Avatar
behind the intake manifold
