Car wont Idle at Cold start After TB Port
Old 11-29-2006, 03:25 AM
lasvegasgs's Avatar
Default Car wont Idle at Cold start After TB Port
Hey guys well here is the story of what happened.
Ported the TB I used Epoxy and 2 pipes to leave a hole. Then my buddy knife edged the Thorttle Blade and screwed it up so it didn't have a perfect seal the car would Idle at like 2k I drove it back home like this and parked it intell I found a TB blade off a 99 Trans Am. BTW I have an 02 SS motor in my car. So I stick the 99 throttle blade in my car and Idle is jumping around 500-1200 and it sometimes dies when its a Cold start I have to keep giving it some gas. So when the car warms up I have a steady idle at 1k like my tuner set it to be. But as soon as it cools down a bit I get that crappy idle that makes it wana **** off. What could it be?
I did search but came up empty handed.
PS. It idled perfect before this porting I did
Old 11-29-2006, 10:34 AM
Trashed's Avatar
mine was doing the same thing so i set the idle set screw (think thats what its called) just adjust it to wear you want the idle to be.
Old 11-29-2006, 05:46 PM
lasvegasgs's Avatar
Where is this idel set screw?
Old 11-29-2006, 07:02 PM
That's what she said...
TheBlurLS1's Avatar
Look at where the blade stop rests when it's in idle position. Theres a set screw that comes in from the bottom. Considering you epoxy'd the holes, you probably didn't leave a big enough hole.
I've seen that epoxy fall off and get lodged in an intake runner on the head, not a good idea. It's been proven not to be worth a **** either. Bo White confirmed (LS1 TB porter extrordinaire).
Old 11-29-2006, 08:45 PM
Cop Car's Avatar
plug your MAF in
Old 11-30-2006, 05:43 AM
lasvegasgs's Avatar
LoL wouldnt that be funny. Only if it was that easy huh
Originally Posted by Cop Car
plug your MAF in
