'00 LS1 throttle screw location???
Old 12-12-2006, 03:54 PM
VTC_WS6's Avatar
Default '00 LS1 throttle screw location???
So i'm reading up on adjusting the throttle screw for idle compensation on cars with larger cams, but for the life of me I don't see the throttle screw anywhere on the throttlebody itself, am I missing something??
Old 12-12-2006, 04:08 PM
That's what she said...
TheBlurLS1's Avatar
Look at the closed position throttle body stop, where the rotating piece rests when it's closed. This piece lands on the screw, you can adjust it from the bottom, but might have to take the TB off.
Old 12-12-2006, 04:26 PM
Kleeborp the Moderator™
MeentSS02's Avatar
You almost HAVE to take it off to adjust it...a big pain. That's why some of the throttle body porters turn the screw upside down so it can be adjusted from the top.
Old 12-12-2006, 09:11 PM
VTC_WS6's Avatar
Ahhh.. and here I am scratching my head lol! Thanks!
Old 12-13-2006, 09:37 AM
Moderator
jimmyblue's Avatar
If you screw with the screw you may have to do a
TPS relearn to get idle TPS% right (back to 0%).
Wonder why people don't drill a pair of holes and
put an idle air bleed screw like carbs. Looked at
that way back, seemed doable, but with tuning tools
there's no need to make shavings.
Quick Reply: '00 LS1 throttle screw location???
