Oil Temp gauge Mechanical or electric?
Old 12-28-2006, 08:08 PM
THE CHOP SHOP's Avatar
Default Oil Temp gauge Mechanical or electric?
I have seen many people running the electric oil temp gauge. I am planning on running some Auto meter Phantom gauges and would like to not run the short sweep. I noticed that there is only a full sweep in mechanical. Is anyone running a mechanical oil temp gauge? I plan on running the sending unit into the piece above the oil filter.
Old 12-28-2006, 08:41 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
ya, ive herd of a few peeps using them, the main thing is to make sure you tie the plastic tube back really well, or even use copper.
Old 12-28-2006, 08:46 PM
SLowETz's Avatar
I'm running an AutoMeter Pro Comp(full sweep) mech oil temp. Works good. Just drill and tap for the fitting in the oil filter housing and you're good to go. As said, keep the sending wire away from the headers-
Old 12-29-2006, 08:58 AM
Thanks guys that full sweep just looks better IMO.
Old 01-14-2007, 09:14 AM
Ok so i am getting ready to install mechanical oil gauge today and the mechanical sender is pretty big. It basically has a pretty large an fitting with a metal tip similar to what a mechanical water temp gauge has. Has anyone found a fitting that adapts well to the oil piece beside the filter?
