Oil filler neck removal...and breather part#
I want to replace my oil filler neck with an open breather. Does anybody have a part # for one that is a direct fit?
Also can the oil filler neck be removed without taking off the valve cover? Does it just twist off?
How do you feel about doing this to reduce pressure in the valve covers? Do you think it will help reduce the amount of oil blowing through the PCV lines?
Re: Oil filler neck removal...and breather part#
I want to know how to get the damn oil filler neck off, too. I had to mess with one for fifteen minutes before it finally just came off. There's a little tab on the valve cover that it snaps on to, but it wasn't real clear to me how to get it off. I twisted and yanked for a while and it finally came off.
I know this is an old post but I wanted to add to this so the next person that searches for this info will have what they need. YES, their is one big tab that goes into a grove but their is also another smaller plastic tab that has to be pushed from the inside with some sort of small tool like an icepick, depress this tab and it will free the filler neck, see photo below.
oh thank god..
Another revival but Im doing mine now and I know about the tab inside but it just wont come out...Do you just reach inside and prevent it from digging If anyone is interested, I can take some better pics. The cover is off right now and Im putting on a breather cap I made myself...
broke oil tab
Hey CF,
I am new to the whole LS F body hobby and I got a little forceful removing the oil fill cap, heard a pop and It popped out. I cannot find the little tab so I am guessing it is in the valve cover. Does this tab pose any danger to the engine? I know its best to try and find it but ... There is so much stuff in the way.
QUOTE=99'CajunFirehawk157;13267741]I know this is an old post but I wanted to add to this so the next person that searches for this info will have what they need. YES, their is one big tab that goes into a grove but their is also another smaller plastic tab that has to be pushed from the inside with some sort of small tool like an icepick, depress this tab and it will free the filler neck, see photo below.[/QUOTE]
