Help me spend $4000.00!!!!!
Ok, here is the deal, I have 4k to spend on the car. See Sig for mods I presently have and tell me what you think would be best bang for buck mods to add for that amount of dollars. I have just recently put a used 4l60e with a shift kit in. There may be a few hundred more to spend but i would like to stay as close as possible to the 4k. By the way car and motor have 93k and alot of runs but its my daily driver too. Thanks for the help and suggestions in advance. Of course if any sponsers want to chime in with deals they are running would be welcome too!
If you plan on keeping the car I would go with a 12 bolt and heads and cam if you think that your tranny can hold the power. You already have some of the supporting mods for cam and heads and on the nitrous with cam, heads the car would be nasty.
Originally Posted by Ace$nyper
Where do you want to improve the car?
Handling 1/4 time braking looks etc.
If I had that kind of money I'd do two items, First True Duals like the Bassani True Dual Kit, then a FAST 90/90 setup. That's almost 3 grand right there. Don't forget about a ported throttle body and ASP pulley to complete all the boltons, another easy 15-20 rwhp. Relocation brackets will help your launch performance. This would be the way to go for the most complete boltons.
or
Look into a good heads/cam combination. Something like AFR heads and a 224 cam will be mild enough for every day driver but still offer up over 400 rwhp N/A. This would be the way to go for the most hp. The price would include installation all the associated components and a tune.
or
Originally Posted by TheBlurLS1
Forged 346, cam, tune. This comes out to about $4k.
400rwhp motor, then you can put some large jets in.
Originally Posted by blacksskid07
heads, cam, 12 BOLT!
Originally Posted by mushroom281
12 bolt and a built trans because i don't see the trans or the rear living up to more hp
