Bottomed out in the Mother of all Potholes..
That sucks my friend hit a nice one a few years ago and bent two of his torque thrusts needless to say he was pissed. But hey it could have been alot worst than that try to look at the bright side I guess.
Ouch...so that's a couple of your SLP LT primaries? I know it might hurt flow a little bit but I don't think it would hurt that bad. Look at it this way - it's only 2 cylinders that might have marginally less flow so the power loss is most likely minimal. If you're worried about it I'm sure a body or exhaust shop could pull the dents out.
Ouch, you should definitely take that pic to the municipality that overseas that road and tell them to not only fix the damn pothole but reimburse you for the damage as well. Might get a result, might not
Originally Posted by pro2low
they might reimburse you! my friends have bent rims and they paid them back for those....why not exhaust?
They would probably try to pull some **** like "Oh, well since your exhaust is aftermarket and hangs lower, that's not our fault."
When I had my SS, I hit a HUGE rock in road and put a dent in my 3" ORY on the driver's side where it connects to the long tube, it didn't feel like it lost any noticeable power. I would guess 2hp MAYBE.
I think you'll be fine! Now in the Z06, I'm PARANOID about potholes and rocks, haha
Looks similar to the dents in my driver side pipes. I came around a turn and hit a rock in the road. Took out my ypipe completely and dented the headers. I replaced the ypipe and left the headers as is. I've put about 30k miles on it since then with no issues. I'm sure it's not optimal, but I'm not too worried about it on a stock cube, stock head motor. Also, with just the mods listed in my sig I trapped in the 110 to 111 range in the 1/4 so it must not be hurting power all that much.
That's what she said...
One of the tubes in my Kooks looks like one of those.
I was coming back from Houston Raceway and hit a huge HUMP sticking out of the road. It wasn't a dip or anything, just a ******* iceberg poking up. 18-wheelers driving down that soft asphalt smashed it up into humps, and one of them knocked the **** out of me.
It was so high, that it knocked the 1" nut off the bottom of my K&N oil filter (truck style).
Did you get that immediate gut feeling when the car is basically resting on the motor and its motor mounts...i was like "OMG holyshit!" and I said that when i was by myself outloud....it was that bad.
Where do all our tax dollars go to and registration renewel's go...."highways and roads"...bullshit, houston has had some pretty rough roads lately.
Well I knew it hit REALLY hard, so I just put my eyes on my oil pressure guage until I was able to pull over (no shoulder on this damn road either). I was really pissed. The next time the headers are off the car, I may heat the pipe up and stick my breaker bar in it to try to get it back into shape.
