Tsp True Duals!!!!!???
quick question...if i bought the tsp TD setup could i have a shop or someone run them all the way out the back instead of dumping them or would i be better off going all custom??
talk to One2Run. He has TSP's and got his piped out the back. The TSP's are about $420 + whatever it takes to run them out the back. Once i get a CME valance, i'm getting mine piped out the back. I don't even want to know how much a custom set of true duals would cost.
It depends, if you are going under the axle, it might end up being the same cost. If you are going over the axle, it will probably better to get something custom. Either way I would talk to your local exhaust shop and get a quote. That way you can see either way what it might cost.
