Need help asap w/ PTB!!!
Well I just bought a S2 ported TB, I installed it and used the sensors it came with. Well when I went to test drive the car the idle was everywhere i figured it might be normal since its more air or w/e coming in. Well after a while the problem didnt stop. I though it might be the TPS so I switched it out with the one from my stocker but still the same problem. Idle is around 2k-2.5k, once its stoped for a while the idle will come back down to 1k-1.1k.
Can anyone help me with what the problem might be?
It came off of a '00 formula and is now on my '01 WS6 if that matter. This is my daily driver so I need it fixed asap. Thanks-
See i thought the the 98-99 were the same then there was the '00 that all alone and the '01-'02 were the same. The I read some where that the the '00 and the '01 were the same.
Thanks-
I'll switch the internals out tomorrow.
Thanks-
