Reuse stock cats?
Old 03-28-2007, 01:49 PM
Adrenaline_SS's Avatar
Default Reuse stock cats?
After getting Pacesetter's
I was thinking of trying to reuse my stock cats for a custom Y to save some $$.
Can this be done? or would I have clearance issues?
How much HP would I giving up over aftermarket cats?
Old 03-28-2007, 01:56 PM
A-Dub's Avatar
I suppose you could....Problem is the ID of the stock cats is smaller than the 3" ID pipe most guys use for a Y pipe. On top of that, depending on your year, the driver side cat has a funky inlet
Old 03-28-2007, 02:11 PM
Reject's Avatar
i was just wondering that myself the other day, i had a custom set up done and was wantin to use some stock cats, i know the diameters are different, but i'm sure the muffler shop could like cut off at were the seam is and put a correct side diameter tubing to match. i was just thinking of idea's to do it. hope to hear how you did yours
Old 03-28-2007, 09:09 PM
Ragtop 99's Avatar
If you were making interchangable pipes so you could swap them in for emissions testing, it would be worth reusing them. Otherwise get some high flow ones.
