What size tap and Helicoil for Heads?
Old 04-07-2007, 05:29 AM
Mazdryk's Avatar
Default What size tap and Helicoil for Heads?
I stripped out one of my rocker arm bolt holes on my Head for my LS1. I wanted to know what size Tap, drill bit, and Helicoil to use for my repair. Anyone have experience doing this? Any trick to do this so that i dont have to remove my head?
Old 04-07-2007, 09:55 AM
Internet Mechanic
BlackScreaminMachine's Avatar
For a rocker stud, I wouldnt even try to heli coil.... just due to the pressures extracted on the hole.... I would have it fixed at a machine shop, they will refill it and redrill it and its done right.
Let us know if you dont do that and how the heli coil goes.
Old 04-07-2007, 11:26 AM
oange ss's Avatar
8 mmx1.25 mm, the kit should have everything you need
Old 04-07-2007, 11:50 AM
Internet Mechanic
That small eh, thats the same size tap I used on my header bolt holes.
