LS6 Intake
Old 04-14-2007, 12:51 PM
Intragration's Avatar
Default LS6 Intake
I seem to remember reading about this before, but search isn't working...
I'm thinking about getting a used LS6 intake off of a 2001 Z06, are all GM LS6 intakes the same as far as performance is concerned?
Also, do all castings have the ribs on the bottom? Are there any negatives to grinding those ribs down, such as sealing or heat stability issues? I'd sure rather leave the coolant lines alone if possible.
Old 04-14-2007, 01:01 PM
Starz T/A 17's Avatar
yea all LS6 intakes are the same, but I would be carful about grinding it down if you dont know 100% what your doing, personally I would just drop 30-40 bux on new collant lines for the peace of mind
Old 04-14-2007, 01:07 PM
I was under the impression that the re-routing of lines entailed blocking certian coolant ports off, which I'd like to avoid...
Old 04-14-2007, 01:33 PM
dpw41285's Avatar
people have been blocking off for years it doesnt matter. plus thats how the new factory one run
Old 04-14-2007, 01:41 PM
2001NBMZ28's Avatar
If you don't want to plug the rears another option is to run two front coolant pipes.
