X or H??
X or H??
Im contemplating true duals dumped and was thinking an H pipe if possible for the sound difference, is it easy to tuck an H under there or is that why most people use a small X instead? How many of you are running a H-pipe??
Tech Resident
most people go with an x-pipe because:
1.) the two systems made for our car, the TSP system and the bassani system, both use x-pipes
2.) the x-pipe give greater peak numbers, and that's what most people are concerned about
which is better? you could go back and forth for ages. i personally prefer an H-pipe. why?
1.) it doesn't push the torque curve up as much, giving better throttle response and low-end power, making it better for a daily driver since you don't have to rev as high to get the power
2.) while sound is subjective, most people will tell you the H-pipe sounds better. it's deeper and more old-school while the x-pipe is more high-pitched and tinny by comparison.
the H-pipe will provide better gains in the real-world powerband where you spend nearly all your time - under 3,000 rpms. while the x-pipe may produce higher numbers above 5,000 rpms, how much time are you really spending there? if your car is a track **** and you like to brag about dyno graphs, then by all means get the x-pipe. if you want more low-end and want your car to sound as good as possible at the expense of a few peak horsepower, go H-pipe. it's that simple.
personally, my favorite is the flowmaster D-port pipe that has the sound/construction of an H-pipe with improved scavenging like an x-pipe. i may go that route when i get my TD's made. sponsors don't carry it, so it should be okay to mention summit carries it for a very good price. i would research that a little bit if you want IMO the ultimate mix of sound and performance. jmm98ls1 has this kit and he has, IMO, the best sounding car on tech.
I have an x-pipe but i would rather have an H. I only have an x because i got the duals from a friend and couldnt pass up the deal.
My original plan was to get and H-pipe setup because i wanted more grunt down low
On ls1sounds there isnt very many H set ups dumped, they are mostly X. i would rather have the bassy muscle car sound anyway so im gonna go with an H. I was also wondering about fitment, i want it tucked nicely, im lowered and dont need to rip it off pulling in somewhere lol..
the H-pipe will provide better gains in the real-world powerband where you spend nearly all your time - under 3,000 rpms. while the x-pipe may produce higher numbers above 5,000 rpms, how much time are you really spending there? if your car is a track **** and you like to brag about dyno graphs, then by all means get the x-pipe. if you want more low-end and want your car to sound as good as possible at the expense of a few peak horsepower, go H-pipe. it's that simple..
Im kind of curious what kind of data you have that supports your statements.
Tech Resident
