LS6 manifold swap question
Did a search but didn't find anything.
What mods are necesasary to install an LS6 manifold on an 02 LS1. I've heard that you have to modify the EGR system but not sure what you have to do.
Re'
Re'
Re'
Re'
No need to install one
How would I know for sure. I was under the impression that only a few came with the LS6 manifold.
Re'
Re'
If you really want to though, you can look at the casting number on the side of the manifold (below the fuel rail, drivers side, center) and see that it is one of the following numbers: 88894339, 88890524, 88890523, or 12561184. All of those sorrespond to the F-Body LS6 Intake manifold.
Hope that helps.
Originally Posted by ONEBADASSWS6
You can know for sure because all 2001 and 2002 F-Bodies came with the LS6 intake manifold from the factory.
Hope that helps.
Hope that helps.
Re'
Yes, all 01-02 cars came with the LS6 intake manifold from the factory. I think he was just giving you a few examples of part numbers that correspond to the LS6 intake manifold. I'm sure there are others. Did you buy the car new or used? I don't know why but maybe somebody previously swapped an LS1 intake manifold on there. What part number is on yours?
this makes me laugh...all 01-02 cars had the ls6 manifold hell some 02s got the block as well.unless you got the car used and some retard swapped for a vette ls1 manifold.believe it or not some dumbass was here a while back asking how to do this because his buddy wanted his manifold and he didnt care about the performance loss.
The number on the manofold is 12573572.
I only know the cars history from mid 04. I was owned and not modded by a friend of my sons. It only had 5k on it when he bought it and apppeared to be stock with only a drop in K&N filter.
Re'
Re'
