misfiring
misfiring
I have a 2002 camaro ss. I bought new MSD coils, spark plugs and wires put them on, and my car started to misfire. so i put the stock coils back on and they still misfire .Check all the plugs and ohmed the wires and still a misfire . please help me
do you have all the wires pluged in right? You could have a bad wire. Its somthing you did with the install. Did you mess with your injector wires at all? something is mixed up. prolly nothing major just somthing you missed on the install. make sure you have everything connecter correctly.
If it wasn't misfiring before, and just started after throwing the wires, plugs and coil packs on then it's gotta be your ignition. Like shini said go get the code pulled, that'll help you pinpoint your problem
