Help with Spark Plugs and Gap
Hi,
I have a 02 TransAm with AFR 205 heads and comp cam 518 lift, Double roller timin, 80mm BBK, 85mm MAF, SLP Long tubes w/ Borla, 410 gears, 30lb fuel injectors, and throtle body bybass. 408RWHP
I called around and everybody told me to run the NGK's TR6 with a 0.50 gap. Would any of you guys recomend this with the application I'm running or somthing different like the TR55's with 0.50 gap
Thanks for the help!!
